So the question is......
headrott
headrott Posts: 5,484
edited February 2014 in DIY, Mods & Tweaks
Which bridge rectifier do I use? I am replacing all the capacitors and the bride rectifiers in my BAT VK-200 since one of the bridge rectifiers went out on the left channel. I decided to just replace all 4 in the amp. I have purchased and have the choice between these 3:
Choice #1) http://www.mouser.com/Search/ProductDetail.aspx?R=DF04M-E3/45virtualkey61370000virtualkey625-DF04M-E3
Choice #2) http://www.mouser.com/Search/ProductDetail.aspx?R=DF04Mvirtualkey51210000virtualkey512-DF04M
Choice #3) http://www.mouser.com/Search/ProductDetail.aspx?R=DB104-BPvirtualkey54720000virtualkey833-DB104-BP
As you can see 2 of the 3 are 1.0A 400V, but the Fairchild rectifier is a 1.5A 400V rectifier. Which do you all suggest?
Thanks for the suggestions all.
Post edited by headrott on
  • zane77
    zane77 Posts: 1,696
    Looks like all the same physical demensions so I think I would go with the higher current Fairchild product. I doubt any of them would sound any different from one another.
    Two Channel
  • headrott
    That was my thinking as well. Use the higher current rating. Plus, Fairchild is an excellent semicinductor manufacturer.
    Anyone else have an opinion?
  • embrown057
    embrown057 Posts: 46
    I always replace them with the Fairchild 1.5a/400v part. Don't over think it, your just going to have a little more wiggle room for surge, won't change the sound at all. What did you choose for the main P/S cap's?
  • headrott
    I am putting the Nichicon "LS" series for the 10,000 uF 80V caps (equivalent to the original). I am replacing all the caps except the 1,000uF 10V caps with Nichicon. The 1,000uF 10V cap is a Panasonic since Mouser didn't have that value in a Nichicon cap.
    The output caps are going to be replaced with Mudorf Silver/Gold/Oil .22uF 1,000V caps. I am expecting excellent reults with the recapping of the VK-200. :smile:
