PA D2000.2 and one sub (how & SVC or DVC)?
wfdTamar
wfdTamar Posts: 1
edited February 2014 in Car Subwoofer Talk
Hi. Looking at a PA D2000.2 amp to drive a single sub. I realise it's simpler to use a (for example) PD D1000.1 amp, but the 2000.2 is available and says it will do a single sub in 'bridging mode'.
So what I need to know is:
1. Should I get an SVC or DVC sub (looking at the MM840 or MM840DVC as I'm limited in space and don't want huge bass).
The input is coming from a Rockford Fosgate 3SIXTY.3 Signal Processor
http://www.rockfordfosgate.com/products/details/3sixty.3
2. Because of the bridging mode in the amp, does that mean I need to feed 2 line level inputs to the sub (which I think I can do from the Fosgate)? Does the bridging mean '2 inputs to 1 output'? Or does it mean simply the two channels inside the amp are bridged regardless of how many inputs?
The rest of the setup is a VW RNS510 headunit to the Fosgate, then to a PA D4000.4 to drive MM6501 fronts and MM5251 rears.
