Adcom GCD-750 left channel not working
stogie
It was playing fine a couple of days ago, now nothing from the left. I plugged in another CD player (using the same interconnects) and left speaker plays fine. I am using the unbalanced connections. I don't have any balanced connectors to try, or would that make a difference? Is there a replaceable fuse inside? Does any one know a reputable repair shop in north to central Florida? Thanks for any help.
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
TT: Technics SL-MA1
Post edited by stogie on
Found the problem- the left cable was intermittently working, then not. Cable has been replaced- all is good.Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
