Headphone Amp Suggestions
gudnoyez
I was wondering if anyone has any suggestions for a headphone amp. I should be getting my HD 598's tomorrow I will mostly use them with my Oppo 105, or one of my Marantz' s so I should be covered there, just wondering what would e a good standalone amp so I can use my headphones on the computer or IPhone or IPod? Budget lets say $150-$250. Any suggestions would be appreciated.
Post edited by gudnoyez on
Well the computer I would recommend the Audioquest Dragonfly v1.0 (AudioAdvisor for 99). For your iPhone or iPod I would suggest something cheaper like a JDSLabs CMoy.
Both pieces together should be around 150 give or take.
But I would suggest looking at 2 different pieces, one for your computer and one for your portable devices. Best way to approach it IMHO."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks I saw that Dragon fly on Amazon how does it work, it looks like a stick you plug into the usb port.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Yup that's basically it. You set it as the default audio device and away you go."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
