passive radiators for RTA-15TL?
Soverign
Howdy all, I have the 15tls, a pair of them, and the man I got them from told me that the original radiators were bad {Rear}, and he replaced them with I believe, regular woofers? So, is that going to be a problem for me? So far, the speakers seem to work well, and I have yet to pull the passives to check both front and rear.......
So, what should one do in this situation? Thanks for anyones help.....Cheers
Post edited by Soverign on
Yes, that is a problem for you. The PR's are frequency tuned and whatever was used to replace them isn't going to be.
If they have been replaced you will need to find the proper PR's and eBay is likely to be the only place you'll find any.Political Correctness'.........defined
President of Club Polk -
Thanks F1nut....I thought that would be the case. A few folks I have heard take off the magnets on different type woofers, and do something else, to make the new woofer similar to the old style. I wonder why Polk won't, or does not make, an replacement for these really cool speakers?
Out for now, and thanks again -
I haven't heard of doing that before, but I can't see it working. If one removes the magnet then the voicecoil shifts, which will cause a scratchy sound. If one removes the voicecoil that still leaves the problem of the proper weighting of the cone to achieve the correct frequency. At best, I would call that a ghetto move. The same frequency issue applies to adding a resistor across the terminals.
At least one of the reasons Polk no longer sells the PR's is that they rarely go bad.Political Correctness'.........defined
They are a valid design approach and are easily tunable. Some fine speakers and credible designers have used passive radiators.. including Polk, ESS AMT, JBL
