Hurricane Nuts
FaustinFaustin Posts: 735
edited January 2014 in DIY, Mods & Tweaks
Looking for advise on using hurricane nuts and machine screws on larger passive radiators. Most of the original pr's use only 4 of 8 holes to fasten the pr to the cabinet. Is it recommended to use all 8 holes and drill out and install hurricane nuts, or just use the 4?
Post edited by Faustin on
  • Toolfan66Toolfan66 Posts: 13,831
    edited January 2014
    I'm sure you would be fine with just the four, but myself would do all eight...
  • F1nutF1nut Posts: 40,214
    edited January 2014
    Other than the CRS/CRS+, what other SDA's only use 4 of the 8?
    Anyway, do all 8.
    edited January 2014
    Anyway, do all 8.
    That's the only one, but all the monitors use 4, but I know you know that.. LOL!!! :-)
  • FaustinFaustin Posts: 735
    edited January 2014
    Thanks for the input. Spaecifically it would be for monitor 10's and RTA 12's.
  • drumminmandrumminman Posts: 3,354
    edited January 2014
    Yep, use all available holes. You'll get much better coupling of the PR to the front baffle, less chance for air leaks.
  • Dr_WuDr_Wu Posts: 56
    Just received an order of hurricane nuts from PE. They stick to a magnet. I thought I read somewhere in here that this is a problem? What's the scoop? Thanks
    Dr_Wu wrote: »
    It’s not a problem... Rock On..... :smiley:
    Domo arigato, Larry-san.
Howdy, Stranger!
