Where to buy ASL online?
organ
organ Posts: 4,969
edited January 2004 in 2 Channel Audio
Anybody know a good online store that sell ASL? I'm thinking about getting this integrated instead of getting the Dyna rebuilt. Shipping the Dyna is going to cost an arm and a leg. I'll buy this int and fix the Dyna in the future.
This is the model I'm looking at: http://www.divertech.com/aq1003dt.html
asl.jpg 78.7K
Post edited by organ on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited January 2004
    Jeffssoundvalues.com is an authorized dealer, and carries the full line.
    Cheers,
    Russ
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2004
    Maurice,
    I'm really enjoying the ASL amp that I bought from Russ (Hoosier21)!! I'll try to get a review posted this weekend if your interested.
  • organ
    organ Posts: 4,969
    edited January 2004
    Thanks Russ. I'll be ordering from there in a few months.
    Frank,
    Sounds great. I'm looking forward to reading the review.
    There's another int I might consider (forgot model #). A little bit more expensive though at $1300 but it's 50w/ch and it can be switched to triode operation at 29w/ch.
    That unit uses KT88 power tubes. Anybody know the difference between KT88 and EL-34?
    Maurice
  • organ
    organ Posts: 4,969
    edited January 2004
    Found another interesting creature for under $1k. It's also 50w/ch. Looks a lot nicer than the ASL but not sure if it sounds better. What do you guys think about Jolida vs ASL?
    www.jolida.com/catalogue/jd302b.html
    Maurice
