amp settings for sub
bbrazil
Just purchase a D2000.2 amp and a MM1240 Sub. I am going to run this speaker bridged off of the amp. I understand setting the gain with a multimeter, but how do I set the crossover on this amp exactly. There is a switch that has "full, hpf, Bpf" where to set that? what about the LPF and the HPF buttons? Where to set the HZ on both hpf and lpf? thanks in advance
Post edited by bbrazil on
I am not sure how to run this amp in bridged mode since you want a low pass filter to be used only. The manual should possibly give you instructions on how to run the amp bridged? Good luck.KEF Q50 mains, M&K center, Boston Acoustics surround, Marantz SR6007 pre, Emotiva UPA-700, Pioneer DV-46AV, Samsung BD-j7500, Sunfire HRS12 subwoofer
