Question about PA660.4
blakmetalemp
I acquired this amp from a buddy so I don't have the manual but he was telling me I can run all four of my door speakers and also still run two subs off the bridged channels, making a total of six speaker running in "tri-mode". From what I have found online this sounds true but my question now is since the subs I have are two Kicker C12a 8 Ohm. Yeah I know there old but they have never been used lol. Anyways, if I hook all my door speakers up to their normal channels and run the two 8 Ohm subs parallel for a 4 Ohm load off of one bridge, will this be any problem? What would the RMS be running this way? Thanks
EDIT: These subs are rated 200RMS I believe.
Post edited by blakmetalemp on
you could do that I would not recommend, you'll have to wire your speakers down to 2 ohms per channel . chan a then wire the subs up to the b chan. make sure your head unit has 2 or 3 sets of preouts, I would look for the matching amp for the kicks i think it was pa230 or something like that and use your
pa880 for the amp for your subs
thanks for the input. I think I'll just wire the 660 amp I have for two channel @ 150 rms bridged at two channels and leave the stock head to push the door speakers, which do sound good, I just want to add some bottom end. not looking to build a thumper. I will however be tapping into the rear speakers with a LOC.
