Yammie preamp question
phoneisbusy
Just had a quick question to the forum. I've noticed a bit of static when I adjust the volume on the preamp. Is this normal or do I need to clean the pot in the preamp? Is it terribly difficult?
Dave
Dave
Time is the best teacher. Unfortunately it kills all its students.
Post edited by phoneisbusy on
Canned air will usually clean it out pretty good. Just be careful cleaning it 'cause they can get fairly hot if the unit has been on for a while. If the canned air doesn't work, usually some electrical contact cleaner will do the trick too. You can get both at most office supply stores or Radio Shack.
Also, if you have an anti-static bruch like you would use for vinyl LP's, they are good for cleaning electrical contacts too. It may be worth it just to pick up a brush for stuff like that.Expert Moron Extraordinaire
If the problem still persists, replacing the pot should be easy. Just make sure you replace it with a of the same value.
Maurice -
Many times this problem will show up when the air is really dry and then go away once the humidity is back up to normal.
Dave
Dave,
What model is your preamp? Some of the older Yamaha preamps used pots that were in a sealed plastic case that you couldn't clean.Proud and loyal citizen of the Digital Domain and Solid State Country! -
I've cleaned/repaired my share of vintage audio over the years and the best I've found for the job has been Deoxite (Part Number 341-200) for really dirty pots and tuners gangs. I follow it up with some ProGold (Part Number 341-225) . If it's not real dirty then just the ProGold. You can get this stuff from Parts Express.
madmax
It's a very common complaint in the winter time because heaters tend to dry out the air. When the air dries out, you get more airborne particles because there is not moisture or humidity holding them down anymore. They get stuck to things with an electric charge...like potentiometers.
Once you get the problem fixed, regular dusting of equipment will help keep this problem to a minimum. Fix it soon too because excessive dust and grime build-up will eventually kill a potentiometer.Expert Moron Extraordinaire
Thanks for all the suggestions.
The Preamp is the yamaha C-40.
Looks like I'll be opening it up and taking a peek inside.
Maybe pick up some cleaning supplies.
regards
DaveTime is the best teacher. Unfortunately it kills all its students. -
Phone,
I have a Yamaha C-80 pre that developed a scratchy volume/balance pot after a few years. I had to replace the pot since it was in a sealed plastic casing. It wasnt dirty, it was just worn out.
I am not familiar with the internal parts of the C-40. You can call Yamaha parts in Buena Park, CA (714) 522-9888 and ask to speak to technician Jim Bennet. Jim has been around for over 25 years and is very familiar with the older Yamaha gear.Proud and loyal citizen of the Digital Domain and Solid State Country!
