RT3000p black bases, working or not!
Inspector 24Inspector 24 Posts: 1,063
edited July 2012 in Wanted (WTB) Classifieds
I just picked up a complete and nearly pristine 5000p system but one of the main l/r bases has been damaged and making rattling sounds.
I still have to open it but I believe all I need is the cabinet, specifically the front plate.
I don't need the amps working, don't need a grill and probably don't even need the drivers, likely just the cabinet in good very good condition.
I'll post pics later to show the damage.
Let me know what you've got and how much you'd like shippe to 84084.
Thanks!
Ryan.
Down
RTiA9 - CSiA6 - FXiA6 - Dual HSU VTF-15H Mk2
Sim2 D60 - Dragonfly 106" Panny 500
Up
LSi15 LSiC - RX-V3000
Post edited by Inspector 24 on
  • Inspector 24Inspector 24 Posts: 1,063
    edited July 2012
    So here's the damage that is visible, haven't removed the driver yet, hoping it's just the cabinet, but at this point I'd take a cabinet, if with a driver just in case, all the better!
    EDIT: DO'H! It attached a bunch of stuff I hadn't intended can't make them go away, so some some pics for fun!
    Down
    Up
  • DSkipDSkip Posts: 14,864
    edited July 2012
    Does it rattle only when the sub is playing, or is the rattle when you move it?
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    edited July 2012
    When playing. Just moved the drivers by hand...they're starting to seize, looks like I need drivers too! :(
    Down
    Up
    edited July 2012
    I'd bet that you need the amp repaired. Mine were doing the same thing, so I hooked up another amp to the woofers and the rattle went away. You might do the same and see what happens.
    audiothesis.com/
    Cabling: Wireworld
    edited July 2012
    I wish it were the amp...It may be bad too, but you can feel the voice coils on the drivers scraping if you move the cones by hand... :neutral:
    So, looks like I need two drivers and a cabinet to make this a complete system...have any extras lying around? :razz:
    Down
    Up
  • sdouglassdouglas Posts: 8
    I know this is old thread but any help would be greatly appreciated. I bought a set of RT3000p’s 8 months and had to send them to Polk for repair. Now, one of the plate amps makes the woofers rattle when producing noise and hums when not being used. I know it’s the amp because I hooked up the other amp and the problem went away. When they “fixed” the amp 8 months ago, they said they replaced all 4 capacitors and voltage regulators in the amps. Looking at the failing amp now(I should have checked before) it looks like one capacitor is older than the rest;as if they didn’t replace it. I don’t know if that’s my issue. I was hoping if you remembered what Polk said the issue was so I could do the work myself. I would send the amp back but had a very unpleasant time with them the last time. Thanks and I hope to hear from y’all soon.
  • mlistens03mlistens03 Posts: 2,105
    Pics of the board?
    Not Tom, or Trey, or Jim
    In a few days, it will be...
    NAD C352
    Monitor Audio Radius R90’s/Polk SDA CRS/Mission Freedom 770 IV
    BJC speaker cables, generic RCA’s
    Technics SL3200 turntable and a Shure M97xE phono cartridge
    Velodyne VA-907 subwoofer
    Lafayette LR-1100 acting as a tuner
    TCC-TC750 phono stage
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • codycatalistcodycatalist Posts: 1,613
    edited August 30
    sdouglas wrote: »
    Do try another outlet somewhere else in your home, I have some Paradigm 90P towers with powered subs in each. In a certain room when the sub amps are plugged in I get a ground loop hum. Probably not the issue at hand but figured I would mention it.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Adcom GFA-545
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
    Yamaha AV-34
Howdy, Stranger!
