Bellari VP130 phono stage info requested thanks
gfonggfong Posts: 1,048
edited January 2014 in Electronics
Purchased a Bellari VP130 phono stage and have a few questions if anyone can assist. Did some searching on the net but could not find much info.
As it does not have a power button, I assume it is fine to leave the unit on 24/7 or should I unplug the power cord at the back of the unit when not using?
If I do unplug does it take this little unit long for the tube to warm up? Does it need that? If I do leave it plugged in how long can I expect the tube to last?
When using the output level, where is the ideal spot to have it set at or is it just like a volume level, put it where you think it sounds best?
I read about some hiss and background noise with using this unit, but with my equipment/connections there are none and I am glad of that. I am using a Ortofon 2M Blue cart with a Pro-Ject RPM 1.3 turntable.
Once I get use to the sound, I think I will try some different tubes just to experiment, there are some good posts about this on the Polk site so no need to ask about different tubes at this moment.
2 Channel Setup: Unison Research Simply Italy Tube Amp, Klipsch La Scala speakers, Rega RP6 Union Jack Edition w/Exact Cart TT, REGA ARIA phono stage, Sony SCD-CE595 SACD, APC-H10.
A/V Setup: Sony STR-5400ES AVR, Emotiva XPA-3 Amp, Polk Audio RTi A9's, CSi A6, FXi A6,s, SVS PB12-NSD Sub, Sony KDL52W5100 TV, Sony BDP-S770 BluRay.
Connections: Atlas Navigator All CU, Atlas Voyager All CU & Atlas Equator MK II interconnects, Audioquest sub-3 sub-woofer cable, MIT EXp 2 speaker cables, AudioQuest NRG-2 power cords, Sennheiser HD 598 Headphones.
gfong aka Greg Fonger
True North Strong and Free... Canada
Post edited by gfong on
  • SCompRacerSCompRacer Posts: 6,873
    edited July 2012
    gfong wrote: »
    I had a VP129 and the manual wasn't much. You can DL a manual for your 130 off this page.
    http://www.rolls.com/product.php?pid=VP130
    I have a tube pre/phono stage and turn it off when not in use. Takes ~ 20-30 minutes to get the electrons sloughing off nicely.:cheesygrin:
    You got it. IIRC turned all the way up I got some undesirable hiss/hum out of the 129. I think they had made the 130 a bit better.
    Rolling tubes can find your best sound combination. You can also google to see what other Bellari owners are using.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • gfonggfong Posts: 1,048
    edited July 2012
    Thanks for the info, bang on to what I was looking for. Appreciate the info on the tube rolling as well.
  • nspindelnspindel Posts: 5,288
    edited January 2014
    I just got the 130. Got a nice deal on eBay for a lightly used one, included the Radio Shack power supply and a couple of extra tubes including the SovTek 12AX7LPS that people rave about with this unit.
    With most of my gear packed away I'm just listening to it through headphones. First issue I have with this piece is that the headphone amp is worthless. Just about any headphone amp in the world can put out enough power to drive a pair of Grados to a high volume, they are very easy to drive. Not this thing, though. Even with the headphone level pot turned all the way up, the volume is nowhere near listening levels. So I'm piping the output of the Bellari into my Grado RA-1 headphone amp in order to get some decent power. I was hoping not to have to do that, but it's not a showstopper by any means.
    Sound is pretty good from what I can tell through the headphones, but I'm already eyeballing mods. I will never use the mute, I will never use the rumble filter. I will never use the output level, nor the headphone amp. Sounds like a lot of nonsense that would be better of being bypassed. Then there are the upgrades to opamps, caps, and resistors that I've been reading about online.
    I guess I need to settle in with this for a little while and decide if it is a keeper or not. Won't really be able to do that until after the house is sold and I move to the next location and set up shop. If I like what I hear through the SDA's enough to keep this thing for the long haul, then some upgrades will likely follow. As with anything else, need to decide if I'm better off investing time and money into upgrading this unit, or just get a different phono stage.
    Meanwhile, this little desktop vinyl/headphone setup I've put together is quite enjoyable, so I'll be getting some good use out of this thing for a while.
  • ken brydsonken brydson Posts: 7,078
    Lasker reported
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
Howdy, Stranger!
