Adcom GFA 555
hertz9753
I bought one on Ebay for $262 shipped on Sunday and it got here yesterday. It is modded with AR RCA female cables for the input. It sounds great.
AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
Sub-Velodyne SPL-1000R
Post edited by hertz9753 on
Congratulations on purchasing an affordable amp that sounds pretty decent. I have had one myself for almost a year now and really like it. Again they are a great bang for the buck. If it were mine I would have a VMM handy and check DC offset at the speaker out leads. Let the amp warm up some and with the preamp connected check across each channel on the DC mV scale to see what it reads.
Enjoy it! Great getting new gear.SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp -
$262 shipped! That's an excellent price for that! And a work horse of an amp. I have one that I use when I need to amp up the power which isn't that often. But it's good to know I have it when I need it!
Have fun. That amp can compete with anything in its class and maybe some above. Adcoms are, in some ways, underrated amps. I remember attending one of the mini-Polk fests and watching two Adcom 565 mono-blocks pretty much outperform amps that cost three to six times their price on "certain" speakers. In other words, the Adcoms, which were the cheaper amps by comparison had, in fact, more "synergy" with a greater variety of speakers than the Bigger Badder Higher End Boys which seemed far more speaker "dependent". Pretty much took most of us by surprise at the gathering!
Enjoy!
Sounds like you got a really sick deal on that sweet little Adcom 555 bro! Always nice to get some new gear for the system:)!
That's a very good price for a solid tank of an amp.Mine was $300 even shipped and have not had any issues what so ever.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Congratulations!!!That is a nice unit! make sure to check bias and dc offset. I would also replace all those electrolytic caps for a healthier and longer life of your amp!Make it simple...Make it better!
Thank's for all the nice comments and info guys!AVR-Onkyo TX-NR808
Sub-Velodyne SPL-1000R -
What numbers should one look for? I have not checked my Adcom GFA-555 mkii.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
If you can get 40 mV and under you are good. Around 50mV and you should be contacting a service department. Mine reads 10mV on both channels which says the amp has very closely matched transistors. However I replaced all the filter caps and small electrolytics on the power supply board.
Keep in mind this is for my GFA-555 MKI and I do not know if you are looking for the same numbers on your MKII.SDA2BTL
Marantz CD5004
Adcom GFA-545
What numbers should one look for? I have not checked my Adcom GFA-555 mkii.Make it simple...Make it better!
$300-$350 is about the going price of the 555 on eBay. $262 is a great get!Do you hear that buzzing noise?
SDA2BTL
Marantz CD5004
Adcom GFA-545
10millivolt? I find it low!!! I would set it at least 20millivolt.Make it simple...Make it better! -
Where should I start measuring?Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Where should I start measuring?Make it simple...Make it better!
I to have an original 555 and was curious about these measurements. Now I do not have a Fluke but I do have a Craftsman Multimter#82015. I used it mainly to check ohm resistance when installing alarms but this is a little different.I have a volt,dc scale,a volt ac scale,an Ohms scale ,and another labled A DC.The+ probe is in v ohm aM
and the negative probe is in common.When I tried I got #s all over the place from 42.3 to 47.3 but then it flutuatates.Am I doing this right and are the reading so far correct. What I did was to take the lead that came from one side of the Adcom to a lead to the speaker selector took it off and then got the reading .A is this the right meter and did I do the right thing.. Also do you have to do both atthe same time.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
First off be very careful. What you want to do is disconnect your speaker leads from your amp. Let it warm up some (5-10 minutes) and with your preamp connected place the red lead of your volt meter into the red speaker out of your amp and the black lead of your volt meter into the black speaker out of your amp. Either be on the mV setting on your meter or decipher the decimal points. Do this for the right and left channel. It should not fluctuate much but you may see a little.leftwinger57 wrote: »I to have an original 555 and was curious about these measurements. Now I do not have a Fluke but I do have a Craftsman Multimter#82015. I used it mainly to check ohm resistance when installing alarms but this is a little different.I have a volt,dc scale,a volt ac scale,an Ohms scale ,and another labled A DC.The+ probe is in v ohm aM
and the negative probe is in common.When I tried I got #s all over the place from 42.3 to 47.3 but then it flutuatates.Am I doing this right and are the reading so far correct. What I did was to take the lead that came from one side of the Adcom to a lead to the speaker selector took it off and then got the reading .A is this the right meter and did I do the right thing.. Also do you have to do both atthe same time.SDA2BTL
Marantz CD5004
Adcom GFA-545
My pre-amp was not on . Time for a new test and again would the lead from the Adcom going to the speaker selector serve the same purpose. It would be just that much easier to get to those wires on top if they infact do come from the Adcom left and right speaker jacks......2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I am not familiar with the speaker selector switch. If it where me I would take all other equipment connected to the speaker out leads off and take the readings directly from the amp.leftwinger57 wrote: »My pre-amp was not on . Time for a new test and again would the lead from the Adcom going to the speaker selector serve the same purpose. It would be just that much easier to get to those wires on top if they infact do come from the Adcom left and right speaker jacks......SDA2BTL
Marantz CD5004
Adcom GFA-545
Why all this trouble? He should just take amp out and check all, but if I am not mistaken, this amp does not have trimmer to adjust dc offset. what I would check first would be the bias and then dc offset later, also I would replace all those old electrolytic caps. the amp has to be disconnected from any source just connected to the outlet power!Make it simple...Make it better! -
This is not good advice my friend. The bias being off is not dangerous to a set of nice speakers. DC offset is. So let him check his offset and then go about the business of setting his bias according to the instructions posted from Adcom IF he feels comfortable doing so. This amp needs to have the preamp connected to get a accurate reading when looking at DC Offset. Every amp is not the same.........Why all this trouble? He should just take amp out and check all, but if I am not mistaken, this amp does not have trimmer to adjust dc offset. what I would check first would be the bias and then dc offset later, also I would replace all those old electrolytic caps. the amp has to be disconnected from any source just connected to the outlet power!SDA2BTL
Marantz CD5004
Adcom GFA-545
