MM1040D Help
02mystang
02mystang Posts: 1
edited March 2012 in Car Subwoofer Talk
Hello all!
Final found a box that wil fit in my 02 Mustang Convertible (and still leave "some" trunk left :wink:). Wanted to put 2 MM1040D down firing (or up) with the box the following specs:
Mounting Depth: 6-5/16"
Internal Volume: 1.7 cubic feet (0.85 cubic feet per sub)
Dimensions: 42" FrontWidth x 36" RearWidth x 7 H x 15" Depth
My questions is this, website calls for Internal Vol of .66 per sub, will .85 be bad?
Thanks in advance!
Post edited by 02mystang on
  • pentoncm
    pentoncm Posts: 379
    edited March 2012
    That is a bit big. A common guideline is that usually you can increase or decrease the size of the box by 20% either way. That is 33% above the recommended which is quite a bit. That size box is closer to the recommended size for the MM1240 that I have.
    The problem with going too big is that you get reduced output and it will seem too loose because its under dampened (lack of punch).
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
