Sda-2
alexholeinone
This could be a repeat of an earlier post, but hear me out. Acquired a pair of SDA-2, and they sound great. Some voice, the singer seems like he/she is in the back on an echo chamber, most would be in the normal soundstage, the IC is connected and i checked the phase of the speakers per the manual. Could the crossover dying??? Help
Pushing the SDA-2 with a Hafler XL600 Amp, with Hafler Iris Pre-Amp, Using a Dual 1229Q TT.
Post edited by alexholeinone on
Congrats on the SDA's, and welcome to CP!:cheesygrin:
There's a ton of great info here about all things SDA.
If the problem you describe occurs at the same place on the same songs in the exact same way, I'd say the problem is the recording. If it's more sporadic, and happens generally at louder volumes, I'd say it could be the polyswitches that protect the tweeters.
You can remove the polyswitches from your crossovers very easily. Either jump them or add a small resistor. Search the vintage forum for "polyswitch" to find numerous threads on this.
Enjoy the speaks!:biggrin:2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
THank you, i will search for polyswitch.
I had the same problem with my SDA-1Bs, a deeply recessed phantom center where many recordings place the lead vocal. Some engineers move the vocals a bit to one side or the other and these sounded fine. Over a period of a month or two the phantom center moved forward until there was no problem. I believe that if these old vintage speakers have been sitting unused for a long time they need some break-in time to recover their original sound. I would play them awhile before undertaking any refurbishment.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
I will give that a try. SDA are so good as i remember. Thanks
