Massive Audio
eloplayspolo
Anyone have any experience with their amps?
Im looking to run a set of SR5250s and a single 12" SR DVC
For the COMPS...http://www.massiveaudio.com/store/product.php?productid=16247&cat=251&page=1
Sub... http://www.massiveaudio.com/store/product.php?productid=16226&cat=251&page=1
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
I dont have any experience with these, but I was able to hook up with a guy around me that swears by them. I dont know if you have seen them in person yet, but as far as looks go. They are really nice looking amps, and they pretty small as well. Even the really high output sub amps are pretty small. They are fairly long, but not at all very wide. I have almost pulled the trigger on of the sub amps, but did not cause I did not know if they would really hold up. The reviews on them from the different places I have looked at all give them great reviews so, that is a plus. The only bad thing I can think of with the amps. Is that the tuning options on the amp are pretty simple unlike the Alpine PDX amps. So, your HU will need to do most of the tuning, but that it neither here nor there. Well if you do decide to get them, post a review on here of what you think. I am curious to know what you think.
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org
