RM2300 Speakers
Hi..
I have a blown RM2300 speaker and was wondering what is currently compatible to replace this speaker with if I can't find a used one. I understand it would be better to buy two but don't want to replace all four. Thanks
Post edited by frt2599 on
I am looking for RM2300 speakers. Would you like to sell the remaining RM2300 speakers? RM2600 if you have that as well?
In case you're still interested, I have a pair for $40 plus actual S&H.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
From 5 years ago and he hasn't been here since. Good luck with that lol..
I need screw fasteners for RM2300 or way to determine size to purchase
Take one speaker to the hardware store and try different screws until you find the one that works.Political Correctness'.........defined
