Monitor Series Speaker Impedance?
isounder
isounder Posts: 3
edited December 2011 in Vintage Speakers
I am trying to determine the speaker impedance spec for two different old Monitor speakers.
One is marked Monitor Model 5JR 45053 on the rear label. The instruction book that came with it lists a Monitor 5JR +with impedance 4 ohms and efficiency 92dB. The Polk website Recent/Vintage products lists a Monitor 5JR + as 8 ohms and 90dB efficiency. Is it 4 or 8 ohms?
The other is marked Monitor Model 4 48264 on the rear label. The instruction book that came with them lists a Monitor 4.5 and 4A both with impedance 4 ohms and efficiency 92dB. The Polk website Recent/Vintage products lists a Monitor 4 as 8 ohms and 91dB efficiency. The Monitor Model 4 I have measures 14.5" high so it can't be the Monitor 4.5 (17.5" high) listed in the instruction book but could be the Model 4A which also is 14.5" high. But the lablel says it's the Model 4 48264. Is the Model 4 the same as the Model 4A?
I don't know what to believe. Any help would be appreciated.
Post edited by isounder on
  • skrol
    skrol Posts: 3,452
    edited November 2011
    Welcome to Club Polk. There are a few variants of these speakers. If you post some pics withe grills off we might be able to help sort it out.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • isounder
    isounder Posts: 3
    skrol wrote: »
    Stan
    How do you take the grills off? Are the grills attached to a frame with fabric stretched over them? I don't want to damage them since the speakers belong to a friend of mine.
  • isounder
    isounder Posts: 3
    skrol wrote: »
    Stan
    I have attached pics of the speakers and also measured the enclosure sizes.
    Polk Monitor 5JR 45053: 19 1/2 H X 9 W X 9 D
    Polk Monitor 4 48264: 14 1/2 H X 8 1/2 W X 7 D
    I am hoping this will help to determine the impedance ratings for these.
    pitdogg2 Posts: 27,072
    should be 4ohm and you can check for yourself if you have a multi-meter. Set it to ohm and stick each lead into the binding post.
  • cristo
    cristo Posts: 231
    Do you have a multimeter?
    The measured resistance across the terminals will be in the ballpark of the correct rated impedance
    (i.e. closer to 8 ohms or closer to 4 ohms).
    sorry for the redundant post - pitdogg's correct post snuck in before mine.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • Joe08867
    Joe08867 Posts: 3,919
    Like Pittdogg said they should both be 4ohms.
  • skrol
    skrol Posts: 3,452
    That looks to be the Monitor 5Jr+
    Specs:
    Freq Resp: 30Hz - 26KHz
    3dB limits: 48Hz - 20KHz
    Rec amplification: 20-125 watts
    Impedance: 6 ohms
    Efficiency: 91dB
    and
    Monitor 4A
    Specs:
    Drivers: 1 - 1" tweeter,
    1 - 6.5" midrange (MW6502)
    Dimensions: 14.5"H x 8.5"W x 7.5"D
    Weight: 32 lbs/pair
    Specifications
    Frequency Response: 31Hz - 25kHz (35Hz - 25KHz)
    -3 dB Limits (55Hz - 20KHz)
    Crossover Frequency 4500Hz
    Impedance: 4 Ohms (6 ohms)
    Recommended Power: 10-100 watts per channel
    Efficiency: 92 dB
    Maximum Output Level 114dB
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
