Bring the Bass Back
RSTERN
RSTERN Posts: 287
edited August 2010 in Car Audio & Electronics
Install a db1212 in the trunk running off a polk pa 1200.1. It sounds muffled, plenty of volume, but sounds like comming frm the guy behind me. Any idea how to get it back up front.
Rob
mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
Post edited by RSTERN on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited August 2010
    what do you have the x-over set at? what kind of car?
  • RSTERN
    RSTERN Posts: 287
    edited August 2010
    95 lincoln mark 8. alpine 9886. set at 80hz. I have the sub facing reward as far back as it will go.
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
  • arun1963
    arun1963 Posts: 1,797
    edited August 2010
    To pull the sub forward:
    1. Lower your sub/mid xover point to the 50-63hz range. But both sub and mid driver on the steepest slope that your hu allows.
    2. Are you using the time alignment on your hu? You need to get the sub and the mids in phase to pull the bass forward. If you are using the TA, current settings plus actual distances from your seating position to the speakers would help.
    3. Try moving your sub all the way into the boot (towards the rear seat) but keep the sub facing rearward towards the boot lid. Not sure if thats how you have it.
  • RSTERN
    RSTERN Posts: 287
    edited August 2010
    moved sub, helped out some. No time alignment on hu. Only setting for sub is 80, 100, 120, 200. Unless I use cossovers on the amps. Should I try to put sub 180 out of phase?
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
  • arun1963
    edited August 2010
    Never liked setting the xover at the amp cause its an approximation at best. But if your hu doesn't give you a lower xover than 80hz, then yeah set it at the amp.
    Also try reversing the polarity on the sub. Your hu has TA I think, but you need the imprint module to activate it. You may want to look at spending that $100 on the pxa-100. It will open up a lot of tuning options for you.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2010
    Are you sure you hooked the pre-outs to the Sub outs on the back of the HU?
    If the sub is getting a full signal it may sound garbled and Distant.
  • RSTERN
    RSTERN Posts: 287
    edited August 2010
    Thanks for the info. Just got put on forcded OT. When I have some time I will mess with crossovers and phase. Thanks again.
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
  • RSTERN
    RSTERN Posts: 287
    edited August 2010
    tried the phase switch, made it worse, will try to mess with cross overs
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
  • arun1963
    edited August 2010
    Get the imprint module. You need the time alignment to get the speakers in phase.
