iPad in car
Installer4life
iPad in car anyone. 99 Expedition. Color is a little off but works well..
Post edited by Installer4life on
It looks like it replaced your stereo and all your AC controls.... does it operate everything?
... and I there I was thinking those Ipads were entirely useless Nice job. -
My fault. The wiring coming out to the bottom left is the A/C wiring. We are going to relocate the A/C controls at a later date. I think we can get a console trim piece from a navigator. This piece has the rear A/C controls in it from the factory. The control panels look like the same size so we think it will be an easy swap. I went ahead and extended the A/C wiring so it will reach. The iPad will go through a processor of some sort then out to the system. No fm/am radio or CD player is needed.. Thanks..
oh I see. That's cool. navigation will be pretty sweet on that size screen :P
Reported^^^The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
