MOMO 10" x2 w/ 600 watts or JL W7 10"
eloplayspolo
eloplayspolo Posts: 1,117
edited July 2010 in Car Audio & Electronics
Currently i have the 2 MOMO 10s installed in a small sealed enclosure. I think it sounds great, its very clean, but as i get a better ear im starting to notice that some of those lower notes aren't coming in like they should, I was going to move to a single SR 12", but if the JL will be able to do what the SR will and sound better, i would go for that. What are your guys recommendations?
Also, its been a while guys, i havent posted here or check for a long time, hope everyone had a great weekend!
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
  • Installer4life
    Installer4life Posts: 256
    edited July 2010
    I think you will love the 10w7. Build the spec enclosure that JL Audio recommends either ported or sealed and you will be fine. One thing to consider is that the 10w7 is a 3ohm subwoofer and your MTX amp is rated at 2ohms for the 600 watts of output.. The 10w7 needs about 500 watts but since MTX under rates their amps you should be ok.
