Amplifier Info
Systems
Systems Posts: 14,873
edited July 2001 in Car Audio & Electronics
Hi !
I'm planning to use 3 MM100.
I want to run them in parallel. Which amplifier is best for this ? The "Digital" Amps are mostly rated for 1 Ohm use . E.g. 1000 w at 1 Ohm. I think, that such amps are underpowered for this use, because they would give 250 W per Speaker. A other solution i thought of, is to use 3 Jl amps reted at 500w each. This is of course a expensive solution. But that's not the point. I need a compact Class-d solution, because i run out of space.
Any suggestions ?
Testing
Testing
Testing
