DJ Used Technics 1200 Mk4
cmy330go
cmy330go Posts: 2,341
edited June 2010 in 2 Channel Audio
I've got a buddy selling one of these for $200. Not sure what cartridge it has, but don't really care, as I would likely change it anyway.
My question is... Do I really want one after they've been used like this? Just wondering if it does any lasting damage to them. Knowing him it's probably been well used, but not beaten on.
What ya think?
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • phuz
    phuz Posts: 2,372
    edited June 2010
    That's a good price, and those decks are nearly bulletproof. As long as everything is in good shape - tone arm, adjustments, pitch control, RCAs, etc - then I'd go for it.
    billbillw Posts: 7,571
    edited June 2010
    The main thing to look at is the tonearm bearings. If the DJ was throwing them in/out of coffin cases and traveling a lot, the weight of the table can sometimes rest on the arm bearings. Check the arm by balancing the arm with zero antiskate. Then see if it floats freely to the center when you turn up the antiskate. Of course, check the main bearing for wobble as well.
  • cmy330go
    edited June 2010
    Thanks for the advise guys. I'll go check it out later this week and give it a thorough once-over.
    HT
    2 CH
  • unc2701
    unc2701 Posts: 3,587
    edited June 2010
    Check the pitch slider and the brake, too.
    The pitch slider should move smoothly- if it was abused, it'll have a gritty feel as you move it ($25 part, not too bad to replace). I can remember if the mk4 has a bump on the on +/- 0 pitch, but when you're on that (and the 0 pitch led should light up), check the strobe to be sure it's accurate.
    For the brake, with a lot of wear on the motor, it'll no longer give you that instant stop when you hit the button. Start the platter, let it get up to speed, then hit stop. It should give you an instant stop and hold- and may run a little backwards if there isn't a record on there. Now, this is easy to fix if it's out of whack- you just turn a pot that's under the platter- but failure for it to stop correctly may indicate that it's had a lot of use. Or it was never set up right.
    Backburner:Krell KAV-300i
