Upgrading my HT receiver
jhw59
I started with a YamahaV663 that has performed flawlessly but that bad old upgrade fever is starting to strike. What are some receivers or integrated 7.1 amps I should look at? Say for $1000 or less. Or is the difference not going to be worth it unless I spend more which will NOT have WAF:) More power is one requirement. Do I really need all the decoding options the yammie offers?
Post edited by jhw59 on
http://www.polkaudio.com/forums/showthread.php?t=100635
"......New AVR intros include five models in the Retail Home Theater Series line, starting with the AVR-991 ($999; July availability). Also new are two seven-channel models, AVR-1911 ($599; June) and AVR-1611 ($399; June)..." -
Have you look into refurbish units? I just bought a $1000-1299 unit for $740.00 + 40 tax. I got a refurbish by Denon 3310ci. I just saw a denon 4310 go for $1009.00 on ebay, open box. If you want onkyo or marantz accesoriesforless have them refurbish.
Anything Onkyo NR series~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
Pioneer sc-25 $949
Onkyo 1007 $999 -
Pioneer sc-25 $949
Onkyo 1007 $999
both are great. and in regards to your current AVR the SC-25 or Onkyo will be a great improvment. I went from the same AVR to the SC-05 from Pio and won't look back. The amp section is fantastic, the features are great, and the price was a no brainer for what I got. The Onkyo is also great. I really like the MCACC for room correction but also heard great stuff for the Onkyo. Go out and see if you can get your hands on either model and try them out to see if you like one a bit better than the other ect
